Help needed desperately with DS2711 - NiMH Batt.Charger IC !
Gromit1
Jan 30, 2011
11
Hi everybody, and Merry Christmas!
Has anyone made ​​a battery charger with DS2711 chip? If so, please, tell me:
1) I intend to make a parallel circuit as in page#7 of datasheet (see attachment) - what transistors can I use instead of FCX718 - I prefer non-SMD transistors that can handle, say, 1Amp of current (2-3 A even better)?
2) Can I use other type of thermistors, like <http://www.futurlec.com/Thermistors.shtml> from futurlec.com (with same 10kOhm value, of course)?
3) What to do with "ICHG" and "IFB"? I assume that ICHG is for connecting power for charging batteries - is 5V sufficient (for 2 bat. in parallel)? IFB is tied to CSOUT pin of IC - how can I use it? Can it stay "floating"? As it is "Current Sense Output" maybe this pin outputs some feedback voltage that can be processed with some MPU or so?
4) Can I use wirewound sense resistor and what power should it have?
Thanks in advance!
ExtractPage1.pdf
  • ExtractPage1.pdf
