Help needed wiring 3 volt garage door opener
Patwil73
Aug 10, 2012
Helo everyone,
I'm new to the forum and was looking for some help in my DIY modification on my motorcyle. I am attempting to wire my 3 volt garage door opener to my high beams so I no longer need to fumble with getting the remote out.
I purchased a voltage regulator which drops my 12 volt battery downt o 6 volts. When I test the lead I want to connect to my garage door opener the multimeter reads -0.0041.
I have a zip tie wrapped around to continuously push the button that opens the door. However, no matter where I attach the wire to the garage door opener I can't seem to get it to power the opener. Any suggestions I what I need to do?
Pat
AndyM
Aug 14, 2012
It is quite possible that the remote requires permanent power (from the battery it originally had installed). The push switch will be momentary, discharging the stored charge.
Could you try this in smaller stages, i.e. power the remote from the bike via your regulator? this would then confirm the remote.
next step, power it from the light circuit (still manually pressing the button.
Finally, it may be possible to fit a "second" momentary switch on the bike in parrallel with the one on the remote
john monks
Mar 9, 2012
685
The positive goes to the ring that holds the battery down.
The negative goes to a connector that is mounted on the board in the center of the ring.
For simplicity I would find a 2.7 volt zener diode and solder the cathode to the wring that holds the battery down and the anode to the connector that is mounted on the board. Then I would find and appropriate size resistor, starting with maybe 470 ohms, connect it in series with the zener. The resistor is what connects to the 12 volt source and the other to the return making sure that the polarity is correct.
I would thing that if you make a mistake and hook the battery up backwards your remoter will become toast.
And if too much voltage gets on the remoter it will become hosed.
Be careful.
