help of a 23A battery to 12v Car battery project
onlyblue
Feb 2, 2013
11
Hi to all
I would like to connect to my car battery a device that takes one 23A battery.
I'm concern when the car voltage goes higher than 12 volts.
How would I do it with out causing problems to the device?
14,487
hi there
welcome to the forums :)
what is a 23A battery ?
what is the device ?
what is its voltage and current requirements ?
lots more info needed so we can help you :)
onlyblue
Feb 2, 2013
11
hi there
a 23A is 12V alkaline battery ideal for small remote control devices such as car and garage door remotes. http://en.wikipedia.org/wiki/A23_battery
The device is a wireless doorbell and I don't know the current requirements
In essence, all you need is to connect it up to the battery.
However, car electrical systems are noisy and you really need to filter the 12V so that you don't get large voltage spikes which will (potentially) disrupt or even destroy the wireless doorbell.
I would recommend that you connect a 220 ohm resistor in series with the +ve leas, and a 1000uF capacitor after that between +ve and -ve. These components will probably take up about as much room as the original battery.
220 ohm 1/4W or 1/2W (or higher power, but it will just be larger)
1000uF 16V or (preferably) 25V
There are other methods of doing this, but these parts can be obtained from pretty much anywhere that sells electronic parts.
onlyblue
Feb 2, 2013
11
Thank you Steve for your reply. I’m not an electronics guy so I had made a diagram. Please let me know if this is the correct way.
Also why should I use a 16v or even 25v capacitor on a device that takes 12 volts?
how much current will take from the car battery? Is there any chance of draining the battery overnight?
I'm also concern if this solution will get hot, especially in the summer?
Nope, the capacitor should go across the + and - terminals at the devide side.
duke37
Jan 9, 2011
5,364
It is usual to show the positive voltages above the negative voltages.
A 16V capacitor will have a little bit of leeway when running on 12V. Overvoltaging any component is obviously risky.
Make sure that the capacitor is connected the correct way round or it will fail.
Here is a schematic of what you want to do.
As has been mentioned, it is conventional to place the +ve rail at the top, an the negative at the bottom.
attachment.php
It's also conventional to have the general flow from left to right. So inputs on the left, and outputs on the right.
onlyblue
Feb 2, 2013
11
attachment.php
Thank you again Steve
It is almost certain that the device draws no current from the battery unless you push the button. That leaves any current draw being the leakage in the capacitor, and that is likely to be measured in uA (millionths of an amp).
So the current drain will be effectively zero.
Likewise, since very little current flows, the amount of heat generated will be very small.
I would advise placing the components (the capacitor especially) in a place that doesn't get too hot. Where the battery went would be ideal.
Be very careful you don't short out any wires or you could have high currents and lots of heat!
onlyblue
Feb 2, 2013
11
I had implemented the circuit but I haven't achieved to have a constant 12 volts.
If I have as input 12.6 volts I get the same as output. Similarly 14.5 inputs 14.5 as output.
I had even put similar components on a breadboard and the results are the same.
Please advice
14,317
This circuit will folow he input voltage, as you have measured. If you want a fixed 12 V output, you'll need a regulator (example). However, even a good low dropout regulator will require at least 12.5 V at its input pin.
Or simply place a 12V zener diode in parallel to the capacitor to protect from overvoltage. However, if your input voltage is below the zener voltage, so will be the output.
Generating a 12 V output from less than 12 V input will require a so called buck-boost regulator
onlyblue
Feb 2, 2013
11
Harald, thank you for explaining, my only concern is having more than 12volts. So in case the car battery drops below 12v is ok,
If I put a 12v zener diode how many amperes I will get in the output?
I would much appreciate it if you could update the circuit diagram
14,317
Here's a schematic:
attachment.php
Note that the cathode of the zener diode is connected to plus!
You may need to add a normal diode (1N4001) in series with the zener, this time the cathode ist to minus! The additional diode will add another 0.6V on top of the zener voltage, thus the limiting will begin at 12.6V.
The zenerdiode will not limit your output current. This is the resistor's job.
