help pls!! memory address decoder design
K
Kelvin@!!!
the question is
Design a decoder for the following using a "138 decoder, NAND gates, and
iinverters":
a 1K memory is connected to a 16 bit address but. the first location of the
memory is to be at 4000H. DO NOT use partial decoding. draw a decoder
circuit that gives an active low for these memory locations.
this is a review quiz i got today in my first microcontroller lecture.
my prof just gave us a super simple solution that totally confused me...
1K = 1024
A0 ~ A9 change
A10 ~ A15 decoded
i understand that 1024 = 2^10
so A0 ~ A9 is used for address.
but what does he meant by "A10 ~ A15 decoded"???
thnx for any help...
Jonathan Kirwan
the question is
iinverters":
1K = 1024
A0 ~ A9 change
A10 ~ A15 decoded
You need 10 bits to address each individual byte in the 1k memory. Since it is
likely that the intended use is to have each byte of the 1k memory to occupy
successive bytes in the memory space, the low order 10 bits of the address are
implied. That's the A0 through A9 that you agree with.
What this also means, though, is that you need to break up the 16 bit address
space (65536 bytes) into 64 distinct 1k sections (that's the assertion from the
instructor about the "do not use partial decoding." He/she wants it fully
decoded to the exact 1k section and doesn't want the memory mapped anywhere
else. This means you need all 6 of the other address bits to decode out the 64
different 1k regions. And you only want exactly ONE of them to be hooked up so
that a low is presented to the 1k RAM at the right 0x4000 start address.
That is, you need to decode this: 0100 00xx xxxx xxxx
A '138 decoder will only decode a 1-of-8 circumstance and that, by itself and
without using the enables, wouldn't get you there. Hence the NAND and INVERTER
options allowed for you to use -- most likely something going to those enable
inputs on the '138. (I see a single inverter required, in addition to the
'138.)
Have you read and understood the '138 data sheet? Do you need to have anyone
explain the solution the instructor provided in more detail?
Jon
K
Kelvin@!!!
it is
occupy
are
address
from the
anywhere
the 64
up so
and
INVERTER
enable
'138.)
anyone
Jon
thnx for your reply
now i understand the 4000H part.
from 0100 0000 0000 0000 to 0100 0011 1111 1111 is the memory im lookin
into...
if the question changes to ,say , a 2K memory connected to the same but
starting at 5000H.
i'll be looking at the memory 0101 0xxx xxxx xxxx, which starts from 0101
0000 0000 0000 and
ends at 0101 0111 1111 1111. am i right?
for the decoder part. is he looking for a active low output when the address
of interest is fed into the input of the decoder??
isn't that a encoder?
for '138, if i feed it with a 011, i should get a output of 0000 1000 which
means im selecting the 011th ouput of the decoder. that's why 138 can also
be used as a DMUX which means make only the Nth, N is the input, output
active.
so let me go back to the question. if it's asking for a decoder, im taking a
number in binary,N, which represents the Nth byte in the starting from
4000H. I'm gonna decode it then produce some result.
if i want to access the 1023th byte my memory, according to the function of
a decoder, i am getting a 1024-bit output which the MSB high and all other
low.
something is just not right here...
please point it out...
thank you very much
petrus bitbyter
Kelvin@!!! said:
the question is
iinverters":
the memory is to be at 4000H. DO NOT use partial decoding. draw a decoder
1K = 1024
A0 ~ A9 change
A10 ~ A15 decoded
Well, a 1k memory requires 10 address lines to access each address. So the
adress lines A0~A9 need to be connected to the memory chip. The first
address you need to decode is
0100 0000 0000 0000
and the last one
0100 0011 1111 1111
or generaly
0100 00xx xxxx xxxx
So you need to provide a chip select for the memory:
CS = /A15 + A14 + /A13 + /A12 + /A11 + /A10
This function does not fit in a 138 so you have to add some other logic.
Google for the LS138 or HCT138 to find out the possibilities of this chip.
Be warned that, although it is not mentioned in the exercise, in practice CS
lines are often activ low.
petrus bitbyter
Lord Garth
0100 0000 0000 0000
and the last one
0100 0011 1111 1111
or generaly
0100 00xx xxxx xxxx
petrus bitbyter
CS is to be active low. The 6 upper address lines are not OR'd together.
Andrew Holme
Kelvin@!!! said:
the question is
iinverters":
1K = 1024
A0 ~ A9 change
A10 ~ A15 decoded
You want 0100 00xx xxxx xxxx
The 138 has 3 enables: G1, G2A, G2B.
G1 is active high.
G2A/B are active low.
You could feed the top 3 address lines to the enables and the next 3
address lines to the ABC inputs:
G2A = A15
G1 = A14
G2B = A13
C = A12
B = A11
A = A10
This way, output Y0 would be your RAM chip select:
Y0 = 0100 00xx xxxx xxxx
Y1 = 0100 01xx xxxx xxxx
Y2 = 0100 10xx xxxx xxxx
Y3 = 0100 11xx xxxx xxxx
Y4 = 0101 00xx xxxx xxxx
Y5 = 0101 01xx xxxx xxxx
Y6 = 0101 10xx xxxx xxxx
Y7 = 0101 11xx xxxx xxxx
You don't need any extra gates.
petrus bitbyter
You are right if you consider the plus sign an OR which is usually done. I
also use to write the * for AND and the + for an OR but the other day I had
to work with a text that used the + for an AND and a | for the OR. Very
uncommon but that's why I was mistaken. So you have to read :
CS = /A15 * A14 * /A13 * /A12 * /A11 * /A10
petrus bitbyter
Lord Garth
petrus bitbyter
I think we lost the OP....
I thought you might confuse the OP which is why I pointed it out. I think
some
text use the asterisk for negation rather than the / most of us use just to
mix
up our heads some more!
K
Kelvin@!!!
some
to
mix
thank you guys very much....
altho the notations are a bit confusing, i'm good with it...
i guess sooner or later im gonna mess up with the notations...
still remember the words my C intructor told me when he reject my code...
"No matter how good your code is, as long as it doens't follow my rules,
it's not completed. Here im the boss, you work for me. Just like in the
industry!!"
i was just using a differnet indent style...
