Thank-you, Upsurt.
Your new schematic is very clear as a GIF file type. But it was huge so I reduced its size, cropped it and made some of its dotted lines solid lines.
I don't think the resistor in series with the load is needed. The voltage gain of the amplifier will be 1 when the load resistance is very low.
I also don't think the capacitor is needed because the output transistors are emitter-followers with a very wide bandwidth, very low phase shift and no voltage gain.
I changed the 47k feedback capacitor to 100k so that the output impedance of the amplifier can be higher.
