I need help figuring what mosfet resistor and zenor to use. I am running a dc dc step down converter off two 3.7 v lion batteries. The controle pin is normally on. It's off when a 20 k ohm pull up resistor is connected from it to positive. I would like to add a depletion transistor , a zener diode in for low voltage cutoff around 7 v but am confused on what transister to use and if I would need a resistor before the zener.
