Maddhung73
- Sep 5, 2015
- 4
- Joined
- Sep 5, 2015
- Messages
- 4
Hi everyone my name is Mike, and I got hooked on electronics about 7 months ago and now Im a fricken freak....lol, Im sure all you can understand that phase?!?! Anyway you guys have an awesome website, and Im honored to be a member! Ok heres what I have, I bought one of those programmable dc/dc converters off of ebay a month back and the farther I got into building a custom enclosure, the more I disliked the 2x16 run of the mill 44780 display, so I came across a cheap Symbol/Motorola barcode scanner at an auction the other day so I bought it cuz it has an Arm core processor that runs 640mb ram, 4" touchscreen, 53 key board, wifi, blutooth, and Windows CE 5.0. So got home n ripped it apart hoping to find some type of ttl, serial, data lines of some sort, I couldnt see any but also Im rather wet behind the ears electronics wise yet. Ok so the dc/dc supply has ttl/ serial outputs and it comes with software intended to be able to control the outputs of power supply via GUI interface on PC. Do u guys think it is possible to boot the lab power supply software via an auto/start function thru windows ce embedded, or it also has sd card built in. The microcontroller in the lab supply is only 8 bit, but it would only have to transmit voltage, and current values to the Arm processor with windows on board. There is next to no info on the web in regards to the power supply, I had to scrape and scrounge to find the manual and software download for it. So I am hoping someone with interfacing skills will read this. Basically I want the Arm/Windows to boot the GUI software for the lab power supply and be able to control it and view it via the 4" touchscreen onboard. Since I couldnt find any serial connectors on the barcode scanner motherboard, I did however find serial and usb pinouts on the ass end of the barcode scanner/ mobile computers battery. Am going to bypass the battery eventually but to get started I went ahead and soldered a serial connector to the before mentioned battery pinouts...weird huh I know...the battery has pinouts on both ends to allow for placing the whole scanner gun/ mobile computer into a serial/ charging dock that connects to PC. Their are 17 pins on the batteries ass that connect to the charging/ data cradle, I soldered a 25 pin serial connector to the battery so I can tap into RS232, usb, 3.3v OUT, and 12v and ground IN, it also has 5v detect. So if anyone has knowledge they wouldnt mind sparing some of their own time I would greatly appreciate the much needed help, it really sucks when none of your friends are into electronics...no one to talk to about them or anything....thousands of Google hours!!!! lol, thanx everyone in advance and if you need better shots of the motherboard just drop me a message. Take care, Michael....Maddhung73
