megaposiedon
- Jan 1, 1970
- 0
Hi guys,
I have an application that requires a 4-20mA signal to drive a ItoP convertor that in turn drives a control valve.. I'm using Nation Instrument's Compact Field Point AIO610 which has only voltage output of range 0-10.2 Volts.
Therefore I require a V to I Convertor to converter that converts 0-10V to corresponding 4-20mA. For this I'm using an IC - AD694 (Analog Devices) which is a precision V-I Convertor.
AD694 Datasheet
So, here come the major problem. I used this IC and I'm getting 4mA for 0 volts but when I change the input voltage..The output current remains constant. Following are my connections
Pin 1 and Pin 2 Short
Pin 3 - Voltage IN
Pin 13 - 12V DC Supply
Pin 11 - Current Out
Pin 5 and Pin 9 Short
I followed Figure 2 give in the data sheet for the connections. Though with unexpected output..
What really intrigues me is the Pin 7. Should I supply a 10V to that Pin ?? or short it with Pin 8..
I didnt find any other interfacing circuits on the internet. Can anyone figure out what went wrong with the connections ??
I would be very much thankful
Cheers
Posiedon
AD694 Datasheet
Pin 3 - Voltage IN
Cheers
Posiedon
