Help with Maxim 713 charging circuit
CJR
Jan 13, 2013
7
I was wondering if it was possible to add a led indicator that lights up when charging starts and turns off when it is done. Also does anyone know if stops charging when the batteries reach maximum capacity?
14,317
Add 1: please don't post the same item twice.
Add 2: The datasheet for the MAX713 shows how to connect status LEDs in figure 18, page 15.
Add 3:
I'm sure you mean when the battery is fully charged, right? Because the capacity is a property of the battery (changing with lifetime), but not of the charge status. And yes, if connected properly the MAX713 stops charging (or goes into trickle charge mode) when the battery is full.
CJR
Jan 13, 2013
7
Yes I'm mean the status of the battery. Thanks this helps out
