high school project
CDRIVE
May 8, 2012
4,960
Whoever wrote the description does not appear to use English as their primary language.
Chris
14,487
Greetings
welcome to the forums :)
so what is it specifically that you dont understand ?
the sensor ?
the output ?
or something else ?
14,317
Pidgin, yes. I translate this as follows:
Method of use:
Connected to 5 v power supply light, induction board did not drop, DO output for high level, switch lamp out on the drop, a drop of water, DO output for low level, switch indicator light is bright,
Brush away the water droplets, and back to the output, the higher level...
AO analog output, can be connected to the MCU AD mouth detection drop in the above rainfall size.
DO TTL digital output also can be connected to the single chip microcomputer testing whether there is rain.
Connect the PCB with the electronics on it to a 5V supply
Make sure the sensor PCB is dry. Adjust the potentiometer for a High level on the digital output (DO). The indicator LEd should be off.
Drop some water on the sensor PCB. The digital output should be low, else adjust. The indicator LED should be on.
The analog output can be connected to the ADC input of a microcontroller (MCU) to measure intensity of the rain.
The digital output can be connected to a microcontroller to simply detect presence or absence of rain.
Hope that helps,
Harald
CDRIVE
May 8, 2012
4,960
Harald, I think there's a decryption position waiting for you in one of Germany's intelligence agencies. :D
Chris
