High side switching.
Jim
I have a radio module that I need to high side switch. (10mA)
Any methods I have used so far have drawn alot of current in their own right
(2mA).
Can anyone offer suggestions or tips for high side switching this module?
I was hoping to use 2uA in the switch. The unit runs from 3v supply.
It needs to be a solid state solution.
Jim
F
Fritz Schlunder
Jim said:
(2mA).
Jim
How about using a low threshold voltage P-channel MOSFET. Sounds like the
perfect type of part to meet your requirements. Any product of a great
number would surely work, but for one possible example perhaps the IRLML6402
(Digikey carries them):
http://www.irf.com/product-info/datasheets/data/irlml6402.pdf
With this kind of voltage level and current demand you could also probably
use 74AC type logic gates or suitably beefy tiny logic parts.
Thomas C. Sefranek
Jim said:
(2mA).
Use a PNP (2N3906) as the series switch, driven by an NPN (2N3904) to
ground.
A resistor (24K) in series with the bases is indicated. This will have a
burden of .1uA
plus the base drive for the NPN.
Jim
| __O Thomas C. Sefranek [email protected]
|_-\<,_ Amateur Radio Operator: WA1RHP
(*)/ (*) Bicycle mobile on 145.41, 448.625 MHz
http://hamradio.cmcorp.com/inventory/Inventory.html
http://www.harvardrepeater.org
