in these pictures is another simple capacitor chargeing circuit i put together with about 5 parts, the 2 diode chain this time i used 2x 1n5404 this time they are rated at 3 amps 400 volts each and i used the same 1m 1/4 watt resister to the neon and on the other side i used the same 100 ohm resister, although the first circuit had 1n5408 diodes in it , this time i dident have any the same left so i tried these ones. i used peaces of a terminal block to secure the diode chain together then i super glued it beneath the lid of a spare circuit box i had, and i allso did the same to the resisters so its all stuck to the bottom of the lid, and i originally ran the input wires and capacitor wires out each end of the box through small holes but i ended up useing these screw terminals instead, as for the neon i dident have any with a 240 volts rateing left so i used a 110 volts one and i inserted it through a hole i drilled in the top ciricuit box lid, and then i secured it with some super glue, now the stick on letterings i put on the top of the box is phv= postitive high voltage input, this is from the disc shaped flyback transformer hv out. the next one is fbr= flyback return this is where the return from the flyback goes to, and nc= capacitor negative, this is where the wire from the high voltage photo flash capacitor negative goes to. and the last one is cp= capacitor positive where the positive wire from the high voltage photo flash capacitor runs to. now i used one of my 12 volts lead acid cell rechargeble battery, so i havent botherd to re measure the voltage in it before i tested it out, after i rigged my flyback driver circuit up to the battery then the flyback, and the rest of the wires to the circuit i then switched it on . this time the neon came on strait away and in the few seconds say 4 to turn it off the neon got brighter as if the capacitor charged up in the 4-5 seconds i then shorted the capacitor out useing a screw driver to find out. and it was, as i got the big pop as usual, so this charges up even faster in a few seconds i couldent beleave it at first but when i tried to time it, the second handle on my watch hadent even reached to the 5 seconds yet, i geuss it took the extra second to turn it off
