Hitachi photographic capacitors
dhp
I'm trying to source some Hitachi photographic electrolytic capacitors.
Part number: CE62P, 1200MFD 330WV.
Physical dimensions are 35mm diameter and 63mm long. I require 12 units.
Jamie
look in DigiKey.
they have a 350 WV @ 1200 Uf with a
40 x 60 mm size radio leads. that be the type that has both leads coming
out of one end..
Digi's number.
P10058-ND
cost aprox $15.00 each.
Sam Goldwasser
Note that these are not photoflash-rated capacitors. They may work or
they may fail quickly.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
