Hobby audio player project noise problem
huseyin34
Nov 29, 2023
6
Hi everyone,
I'm new in here. I designed a controller card project and the card can switch some devices with relays, dfplayer mini to play sounds from sdcard, external bluetooth music player card is connected to the circuit. cd4066 used for audio switching between dfplayer and Bluetooth audio. But there is noise in audio. 12volt power supply is used with 7805 regulator. Bluetooth Audio and amplifier also uses same power sources from the board. Can you please review my circuit ?
What you provided above is not a "circuit diagram" but a pcb layout and as such, difficult to interpret.
I would imagine though with audio, you have not considered noise injection from such things as power supply and having necessary ground shielding where required.
huseyin34
Nov 29, 2023
6
Where should I connect the ground ? Can I connect to the any ground point ?
Delta Prime
Jul 29, 2020
2,996
Welcome to Maker Pro. :)This is all very new to me...
Clarification please.
Is this a prank?
You designed it.
huseyin34
Nov 29, 2023
6
There is noise problem in the sound. This is my first PCB. So this is why I asked.
huseyin34
Nov 29, 2023
6
How can I apply ground sheilding. I'm newbie
