Does any one know how well this would work? The potentiometer is a substitute for a plant, the idea being that as the moisture in the pot decreased the resistance would increase, activating the motor which would pump water into the pot.
maybe I don't understand this at all, but would it work if you replaced the SCR and the NPN transistor with a PNP transistor, meaning that as the resistance of the flower pot increased there would be less positive voltage on the gate of the PNP, triggering it? or do i just have a bad understanding of voltage?My guess is that the motor would either always be off (best guess) or always on (unlikely).
If the SCR has a very sensitive gate, you *might* get enough current through the 100k resistor (shown as a pot, but not connected in a useful way) to turn it on.
In this circuit a decreased resistance would cause the SCR to trigger. And in any case, once it's on, it will stay on (presuming enough current flows through it).
You need a circuit that is turned off when the resistance drops. And you probably want the trigger point adjustable because some plants and some soils may require different amounts of water (or change resistance differently).
I can think of a fairly complex circuit using a comparator which might work (well, it's complex compared to this) but maybe someone else can post a simple circuit that might work.
