I can give very little information about this project as it is for the Google science fair, so I can not reveal the reason that I require this information.
Does anyone have any suggestions for a high relative permittivity material, available in thin sheets, that can either be bought online or would be accessible within my home. I need to make a > 1 Farad capacitor in under about 2m^2, needs to have a breakdown voltage of above about 40 volts (will be charged with roughly this many volts across the plates) and needs to have an effectively indefinite lifetime. The dielectric material must be a solid. I am operating under the capacitance equation:
Yes I have done my research, no I not going to kill myself.
I plan to use aluminium foil (kitchen foil) to make up the plates, using two plastic plates either side, screwed together, to keep the plates in contact with the dielectric in compression. Will the idea of using aluminium foil for the plates work?
This appears rather strange upon re-reading, however I have run out of ideas for the dielectric material.
