Hot air gun plug standard
camerart
Aug 18, 2010
140
Is there a standard pinout for hot airgun plugs?
Camerart
Martaine2005
May 12, 2015
5,318
Hot air gun? What type?
mains or 24V?
Paint stripper type or hot air solder re-work type
Martin
camerart
Aug 18, 2010
140
mains or 24V?
Martin
Hi M,
Re-work type, as the fan is 24V it may be 24V, but I can check. The plugs are the aircraft type.
camerart
Aug 18, 2010
140
Martaine2005
May 12, 2015
5,318
If you give us more information on your unit, we may be able to help you further.
As you have seen, some have more connections than others.
But we're guessing as you have not supplied any info at all.
Martin
camerart
Aug 18, 2010
140
Martin
Hi M,
It's called Mark Ethan rework staion, but I don't think it is a genuin one, as the ones, I search for aren't like it, so no real information.
It appears that I'm going to have to open up new guns and check they are the same as the socket, I'm going to fit.
I wonder why the ones I've seen don't have hot airgun sockets?
Martaine2005
May 12, 2015
5,318
I got a little lost and confused......
A soldering iron has the connector.
The heat gun has a tube. This hasn't got a connector.
Martin
camerart
Aug 18, 2010
140
Martin
Hi M,
Easy done.
The station has a wire but not socket (I'm about to fit one)
The new gun, has a plug, and has the heater in the handle.
Once I get it all fitted, I may be able to check a new heatgun, by resistances on the plug, without taking it apart.
Cheers, Thanks for your help, C.
Martaine2005
May 12, 2015
5,318
This one here on Amazon has the same amount of pins and a wide choice of units it fits.
Still confused though!.
Does your station have a connector? or are you adding a connector to it and a new heat gun?
Martin
bertus
3,882
Then there is here a teardown of the station:
It will explain the parts in the station.
Bertus
