We wish to prepare for emergency - such as power outage because of
earthquake or hurricane or flood.
When power goes out we want:
1. lighting - battery powered florescent lights seem to be best?
2. phone - charge cell phone battery and direct line phone
3. laptop computer battery charging
4. get to watch TV - may be off the air when cable goes out. So TV tuner for
the laptop computer
5. Microwave to cook simple stuff or boil water.
How can we get power source from - car battery?
Any small and simple electric generator to charge the car battery?
12VDC to 115AC convert? 400 watt sufficient?
This is what we come up with in our meeting of brain storming.
The biggest discussion were about the spoiled food in refrigerators.
Your comments and suggestions please.
Just get a little Honda generator. The eu1000i, or the eu2000i. They are
reliable, light-weight, fuel-efficient, very quiet, and produce very clean
AC power. They can also handle large surge loads such as an electric motor
starting up. (e.g., power tools). Oh, they are kind of expensive, but you
get what you pay for. ;-)
If you want to run stuff inside the house, you will need long extension
cords since you can't put a generator inside the house with you...
You can use this thing to charge any batteries you want, including your
car battery (with a suitable charger).
If you have to do without grid power for a long time, make sure you have a
Coleman stove that runs on unleaded gasoline, and I think you can even get
gas lanterns that burn unleaded. If not, get the white gas lanterns and
keep some white gas for them. Of course you need to keep 10 or 20 gallons
of unleaded gasoline around to run all this stuff. Use a fuel stabilizer
for the stored fuel. Oh, and extra mantles for the lanterns.
The microwave is questionable, but if you have to boil a lot of water it
might be just as efficient to use the microwave as the Coleman stove, and
I think the Honda eu1000i could drive it. The eu2000i could definitely
drive it.
Since you will have the generator, you can use rechargeable batteries for
flashlights and such. But whenever possible, try to just use the Coleman
lantern.
Might as well keep plenty of D-cells around, too, and relatively cheap,
dim flashlights that use them. Mag lights are cool, but the bright bulbs
drain batteries fast, and the filaments are more likely to break if you
drop the flashlight. When your eyes are dark-adjusted you need very
little light to see. So I find that at night, the flashlight puts out far
more light than needed anyway.
I don't see what you would want a computer for at all. Your DSL probably
won't be operational. But you can run the generator to recharge your
laptop as needed.
Don't forget canned food and water. If you already have drinking water,
you may not have to boil water at all.
--Mac
