How Can 1 Watt =1000v ???
roonyroo
Jul 13, 2012
13
Im still trying to understand how electricity works ...
From what I understand Volts is the initial energy or power of a current
Watts is the amount of energy which travels per second
& Amps is the amount of electricity stored
So 1 watt is the speed of electricity travelling, not the actual amount of energy travelling through a wire?
14,317
Sorry, your understanding is not to the point.
Volt is the unit to express voltage which is the potential difference between two points (e.g. two poles of a battery). The more voltage, the higher the potential difference. Voltage alone, however, is no measure for power. Compare this to the pressure in a water system. Pressure alone does not do any work. Only if there is movement of water involved will there be work.
Which leads me to the next point: current. Current is the flow of electrons within e.g. a wire. Current is measured in amperes. Coming back to my above analogy compare current to the amount of water flowing per second through the water system. Lots of water is equivalent to lots of current. Still, Current alone is no measure of power. Lots of current without voltage means no work done. Take the water example: If you have a flow of water no work will be done unless this water works against an obstacle (e.g. a turbine) where a pressure will develop. In this case we have lfowing water (current) and pressure (voltage). Only´the can work be done.
Which again leads me onward to the concept of resistance. Let us ignore the more exotic aspects of supraconducters and the like. Electrons moving through a medium (current through a wire) are constantly opposing the atoms of the medium. This hinders the flow of electrons. The effect is called resistance and can be expressed by Ohm's law: Resistance = Voltage/Current.
We now have a voltage that exerts pressure on the electrons causing a current to flow against the resistance of a wire. You get the concept?
As you are surely aware the current through the wire causes energy to be converted from electrical energy to heat (I'll deliberately ignore motors and lamps for the moment). The more energy is converted, the more heat is generated. This power is expressed in units of Watt (symbol W). 1 W is defined as the product of 1A*1V. Or equivalently 0.5A*2V etc. The absolute value of voltage or current is irrelevant as long as the product stays the same. Going back to the water analogy: You can drive a turbine either with little water that has high pressure (e.g. falling from great height) or with a lot of water at low pressure (e.g. from a flowing river).
Of course you can also have lots of water falling from great height making for much more power or you can have little water (from a small rivulet) at low speed making for much less energy.
None of these concepts has anything to do with the storage of energy.
I hope this explanation is helpful to you.
14,487
No, Watts = Volts x Amps, it has nothing to do with the "speed" the electricity is travelling as that is relatively constant.
Altho keraynopoylos's link gives an anology of electricity, its not overly helpful and it doesnt answer your questions/misunderstandings
Harald's explanation gives you a more realistic explanation of what it is all about.
I suggest you get some books on basic electricity and do some online googling for some good information.
After doing some reading, anything you dont really understand, come back here and ask specific questions on thos points :)
cheers
