How can a MOSFET in TO220 handle this much current?
sumeryamaner
May 29, 2017
50
Forgive me for this dumb question please but I cannot understand it.
Let's say we have a MOSFET IRF1404. The specs say that it has a VDSS of 40 V, an RDS(on) of 0.004 ohm and a continuous drain current of 202 A!
This MOSFET resides in a TO220 case.
How can it be possible that 202 A current flows through it's contacts?
(Btw. 202 A * 0.004 ohm = 0.808 V and this results in 163 Watts power dissipation. The specs say that it's max. power dissipation is 333 W. On the paper everything seems OK).
What am I missing? How should I interpret the datasheet figures?
Thank you very much.
bertus
3,868
Did you read this on page 2:
Note 6 : Package limitation current is 75A.
Bertus
sumeryamaner
May 29, 2017
50
Bertus
Great point. Thank you. But now I have two more questions:
1- Package limitation is 75 A and there is no other package option for this MOSFET. So why the 202 A continuous drain current? How should I interpret this?
2- Is 75 A OK for the source lead of the MOSFET?
14,306
Just marketing speech. As stated this is a calculated value up to which the junction would presumably not be destroyed. Better to market the transistor as 202 A type than as 75 A type. Always read the small print.
Obviously yes as the leads are part of the package.
bertus
3,868
Here I found an other reason for the limited current of the TO 220 mosfets.
The bondingwires between the chip and the legs are very thin and will burn when to much current is going through them.
On the digikey page on cooling you will find an image of the internals of a TO 220 (figure 1):
https://www.digikey.nl/nl/articles/heat-sinks-a-step-by-step-guide
Also the NXP selection guide has a nice comparisson on the different mosfet housings and their capabilities:
www.nxp.com/docs/en/product-selector-guide/75017590.pdf
Bertus
Wollowstone
Mar 26, 2018
18
The Vdss of 40V is the minimum garanteed voltage that can passthrough the IRF1404.
The 121A is for a short pulse, as stated in the annotation (4) of the section Electrical Characteristics.
Use the SOA (figure 8) to have an information which COMBINES voltage passing through AND current passing through ... but NOT JUST the maximum current or just the maximum voltage which can pass through the transistor. Figure 8 is for 25C without heat radiator, you may have to normalize accordingly figure 4 if temperature greatly differ than 25C.
I used the datasheet at http://www.irf.com/product-info/datasheets/data/irf1404.pdf
As example, for a single pulse of 10 ms of 10V, you should not use more than 32A. For a continuous current, figure 11 seems to indicate that we can generate not more than 20% heat, so I would reduce to 25A in that case... or do the computation at long.
