How can I tell a LED is blown out?
V
Victory
Is there a visual way of sussing whether a LED is blown out? Testing
it with a battery confirms it is blown out, but I wondered if there is
a visual way of seeing the actual burnt out parts...
Eeyore
Forget it.
Graham
David Harmon
On Sun, 16 Mar 2008 09:30:17 -0700 (PDT) in sci.electronics.design,
Only if you can remove the plastic and examine it under a
microscope.
Tam
Hope your battery was at least 3V, with a current limiting resistor.
Tam
StickThatInYourPipeAndSmokeIt
Forget it.
Graham
"sussing"?
What a stupid word.
Electronics is scientific.
LEDs are scientific.
Why would someone use a term that is at best slang?
The term "examining" seems much more appropriate for a technical
question.
"sussing" sounds like adolescent rule breaker slang.
Tam
Yes. As opposed to a test for a blown LED, it actually would create a
blown LED every time.
F
Fred Bloggs
StickThatInYourPipeAndSmokeIt said:
"sussing"?
What a stupid word.
question.
It's a valid English language word, derived from suspect:
tr.v. sussed, suss·ing, suss·es Slang
1. To infer or discover; figure out
F
Fred Bloggs
You can hang a photo-diode/detector around there to give you an
indication, or probably just as good an I-V detector, it's probably
working if that's right...
Looks and sounds like slang, and the criminal element sticks out like a
green thumb.
It fucking sounds like recently coined gang boy lingo.
Got any etymology on it?
Paul E. Schoen
If the LED got blown out by an extreme overload, such as applying 120 VAC,
you would see the damage, but in most cases it is much more subtle.
Actually, the Light Emitting Diode changes to a Darkness Emitting Diode, or
DED :)
Usually an ohmmeter, especially in diode check mode, will provide just
enough current to see some light, and it will conduct in the proper forward
bias direction. But it may not work on LEDs with higher voltage, like blue
and white varieties.
Paul
F
Fred Bloggs
DED :)
Paul
It's hard to tell if this is a high rel application or an incoming
inspection requirement, I'm starting to "suss" it's the latter:)
Crimany! The retarded word loyalty level in here is ridiculous.
Michael A. Terrell
They're just trying to make you feel like you're at 'the home',
retard.
BTW, its VERY appropriate for 'dimbulb' to chime in on a thread about
a dead LED. :)
aioe.org is home to cowards and terrorists
Add this line to your news proxy nfilter.dat file
* drop Path:*aioe.org!not-for-mail to drop all aioe.org traffic.
http://improve-usenet.org/index.html
H
Hot Jock
.... Actually, the Light Emitting Diode changes to a Darkness
Emitting Diode, or DED :)
Shouldn't that be a Darkness Using Diode?
John O'Flaherty
green thumb.
Merriam-Webster dictionary:
suss [by shortening & alter. fr. suspect] (1966)
verb transitive
1 chiefly Brit : to inspect or investigate so as to gain more
knowledge — usu. used with out
2 chiefly Brit : figure out — usu. used with out
If it was adolescent slang in 1966, it's long since grown up.
Rick G
Now I can see how people try to destroy a group by getting side
tracked about some obscure word and avoids answering the question with
an honest answer. There is no values with ignorance... The real answer
about seeing a blown LED is to say that you need a microscope to see
damage to the die or wires. How hard was that???????
Yag1064
Joe Brophy
DED :)
Paul
Like he said...plus when a LED is transformed to a DED it will no longer emit any light regardless of being visible to the
human eye's spectrum or not. Instead they usually tend to emit darkness across the entire spectrum. Maybe there is a way
of modding a "darkness sensor" to measure the effect? regards, Joe.
Yag1064
That's called "visual inspection", and will only indicate a failed
device if said failure was such that physical damage would be visible
during said inspection.
We don't want to know what you have that is hard. Keep it to yourself.
Just so you know, jacking off at the mouth about others "destroying a
group" puts you in the same box, dipshit.
Richard Henry
Then it would always be right.
Rick G
Dip-Shit ya, your right. This group is called sci.electronics.design.
I thought there was some knowledge to be gained. I see your point!!
It's better to make fun of people than it is to help them. It seems a
waste of a good resource for knowledge. Your command of the topic is
pretty obvious. Good Luck to members of this group. I hope you are
able to separate the wheat from the chaff.......
