How do I convert 0-5V to -10V +10V differential?
bazooka40
Aug 19, 2011
Hi,all
I have a DA IC(AD5668) whose output is 0-5V. I
want to transmit the singal with diferential (-10V to +10V)
how would I go about converting the signal
from one format to another.
Frequency is 8KHz
Thanks.
Resqueline
Jul 31, 2009
2,848
It's called converting an unipolar signal to a bipolar signal, and this place has a design example & guide.
You'll either need different reference voltage & resistor(s), or another amplifier with a gain of two after that converter, to get +/- 10V.
daddles
Jun 10, 2011
443
This is probably easiest to do with an op amp that has a DC offset of 10 volts and a gain of four.
