how does a PULSE code MODULATION WORKS?
leonheard
Jan 25, 2013
12
will this work?
1. I add in the receiver 4 D type flip flops, with clock input and the Data input
2. I send the code from the IR transmitter example 1 1 1 0
3. the 4 D type flip flops will “detect” the 1 1 1 0 signal (Wave length on/off time) in its INPUT pin, and its OUTPUT will be “exactly” the same code as the IR transmitter.
dunno, will this somehow also work?
Laplace
Apr 4, 2010
1,252
Is the IR transmitter/receiver designed for PCM transmission? Otherwise, how will you handle clock generation, clock recovery, and signal framing?
