how does a PULSE code MODULATION WORKS?
leonheard1
Jan 26, 2013
14
When I press a button in my IR transmitter it will send binary codes example.
1 1 1 0 with a 38 KHZ carrier.
The IR receiver device will detect the 38 KHZ ( with the filtered code, 1 1 1 0) and will let it pass.
BUT… how does the device know where to put the 1 1 1 0 code? does it have some sort of low pass filter or something ?
http://www.tpub.com/neets/book12/0217.GIF
audioguru2
Apr 6, 2004
12,022
A code that is 14 is made with three bursts of 38kHz (the ones) with a short pause between followed by a long pause (the zero).
Look at the datasheet of a TSOP1738 to see.
remonx6
Sounds very interesting and helpful! Thanks for sharing leonheard.
PCM stands for Pulse Coded Modulation.PCM is uncompressed sound data.Each sample's amplitude is measured and stored as a number. Pulse-code modulation (PCM) is a method used to digitally represent sampled analog signals. It is the standard form of digital audio in computers, Compact Discs, digital telephony and other digital audio applications.
If u need more info watch youtube video on it
www.youtube.com/watch?v=YJmUkNTBa8s‎
If you want to calculated Pulse Coded Modulation or Impedance then use this Engineering Tools. About 38kHz Just now i check it in this online software.
http://actpcb.com/pcb-calculator
If u need more information about PCM email me. Helpful link For New engineers.
Eng Remon
