How much mW is a typical IR diodes used in TV remote?
DYORD
Oct 23, 2009
5
I'm planning of doing an invisible flashlight.. around 7-10Watts equivalent.  I'm not very familiar with IR's.. but i know these have been used in handycams with night mode.  I want to do just like that in DSLR's for indoor photography.
If you have any suggestions.. please also tell me how to do it.
another question:  in every diode, is it equal to 1 AA size battery?  If i make it 2, will it get brighter?
Hero999
Oct 28, 2007
2,433
What's DSLR?
IR remote control LEDs aren't that powerful, you'll need a lot of them to get 7W to 10W.
7W-10W is quite a lot of IR, certainly more than a 100W incandescent.
Does it need to be continuous or is it a pulse, like a camera flash?
Obviously an IR LED is much smaller than an AA cell and of course using two LEDs will make it brighter.
DYORD
Oct 23, 2009
5
DSLR = Digital SLR - camera..  i would need a continuous light.    What kind of IR does a handycam have anyways?  How much AA battery to light 1 IR LED? If I use 2x AA battery, will it make the IR brighter?
Can anyone give me other options aside from IR LED's...?!
Hero999
Oct 28, 2007
2,433
I don't know, I would guess 800nm to 1000nm.
Look at the datasheet, ask the the manufacturer.
A single AA cell could be used to light an LED but you'll need a boost converter.
It depends on how you design the circuit, an IR LED powered by two AA cells won't necessarily be brighter than it would if it were powered from a single cell but it will last for longer.
An incandescent lamp with an IR filter.
DYORD
Oct 23, 2009
5
thanks for the reply... i kinda like the IR filter... but will it be invisible with a normal eyes?  and.. will it be visible on a digital camera?
Hero999
Oct 28, 2007
2,433
It won't be completely invisible, some visible light will get through so you'll be able to see the filament dimly glowing red.
I don't know, it depends on the type of camera, I'm no photography expert.
DYORD
Oct 23, 2009
5
I found something that I think I'm looking for...
http://www.rentron.com/remote_control/IRLED.htm <--- look for long range IR LED
940nm...  I'm planning of doing 7-10 pcs... on series connection... should I be doing series connection of
batteries too?
Hero999
Oct 28, 2007
2,433
Looks good as long as you know that the maximum continuous forward current is 100mA which will typically output just 35mW so you'll need to use 200 to get the 7W of radient power you originally wanted.
The half angle is only 17
