how repair induction stove
vrak
Dec 4, 2014
5
Hi All
My incuction stove got spark near Plug socket while working
Input : 230V 5A.
An any one tell what are the Service Porcedure for Fault Rectification
shrtrnd
Jan 15, 2010
3,903
Who's the manufacturer and what's the model number of your stove.
The vast majority of problems I've found with these units is the actual connection to the inductive heating element.
Check the induction coil connections and make sure they're making good contact. (WITH THE UNIT UNPLUGGED< NO POWER).
I'd also be checking (WITH THE CIRCUIT BREAKER TURNED OFF), the power socket outlet itself. The socket contacts may be so worn that you have intermittent contact.
Power socket outlets experience wear over time, and the socket manufacturer may not make the best quality sockets.
vrak
Dec 4, 2014
5
Thanks for your valuable sugesstion
Its Butterfly Make
shrtrnd
Jan 15, 2010
3,903
Pay particular attention to the induction coil connections. I found that the AC causes vibration, and the contacts to the coil can work themselves loose.
73cat
Dec 30, 2014
7
Hi All
Input : 230V 5A.
Try to contact service center to get help.
