Jack
- Jan 1, 1970
- 0
sorryDon said:---------
Your point does violate the known laws of thermodynamics and conservation of
energy. If you had a heat engine and pump without any losses at all- the
best you could do is to have it run itself with nothing left over to do
anything else. That is- you could spend a lot of money to have something
that does nothing worth while. If you have losses as all real devices will
have, all that will happen is that the device will need a net input of
energy from some other source in order to do nothing worth while. Look at
the thermodynamics of heat pumps/engines.
This approach to "perpetual motion " is not new- nor is it's failure to
perform.
there is no violation of any law of thermodynamics in the above example.
Heat pump uses 1 kWh of energy and generates 3kWh of energy.
More energy is generated than used.
Otherwise, what would be a sense to install heatpump ?
But heatpump doesn't generate extra heat energy, it only transfers heat
ebnegy from one medium to another.
But give up heatpump.
I would like to build now "heat fuel cell membrane" like in reverse
osmosis to have RO forced water flow to generate electrical energy.
To avoid contaminating a membrane I would prefer to use H2O + CO2 in one
tank and H2O in another tank, seperated by RO membrane.
Idea is quite new, to combine "water fuel cell" with RO "remote osmosis"
to force water flow through the membrane.
To build water fuel cell membrane acting also as RO membrane may take
some time
but that approach is ok and has nothing to do with your supposed
violation of the laws of thermodynamics.
Thesis:
If you have 2 different mediums, there exist (heatpump) fuel cell
membrane acting also as RO membrane to generate electrical energy.
You can have water flow induced by convection, combining Stirling
engine, heatpump and water fuel cell combined into one device,
generating free energy.
Jack
Inventor of Tomosonography and Tomoultrasonography
______________________________
Global Inventors Organization
17 inventions for auction sale
starting bid $ 850 a piece
