How to de-solder?
juntjoo
Jun 8, 2015
142
Will this ever work? I've been at it forever and I'm wondering if this basic iron is sufficient. I think I've done it before with a iron like this. What's the trick?
juntjoo
Jun 8, 2015
142
Thanks for any tips but I cheated and hopefully never have to de-solder again.
Minder
Apr 24, 2015
3,561
For large areas and stubborn jobs, I made myself a someting similar , a heavy duty iron from a bar of copper rod, and heat it up really good with a propane torch.
You may need something like this in order to maintain heat for larger jobs.
juntjoo
Jun 8, 2015
142
Ah so my cheating with a torch isn't so much cheating? People often do this?
Martaine2005
May 12, 2015
5,318
I wouldn’t say often!
I’ve never done it. I buy the tool for the job. These days, a solder station is popular.
Your iron tip is too dirty, clean it and use flux on the joint along with fresh solder. Then try and desolder.
But your iron may only be 10W or 15W which is not sufficient for your particular situation. The art of soldering in MY opinion is hot and fast not warm and slow.
Use whichever method works for you.
juntjoo
Jun 8, 2015
142
These balls of solder avoiding the work area like the plague are really offending me. I cleaned the area particularly metal parts with power tools for God's sake then applied flux. So what are my crimping options? Bare stranded wire to these posts and how do I bridge them? I tried putting a dirty piece of bare wire in there so maybe that was my first mistake
juntjoo
Jun 8, 2015
142
So how many watts then?
Martaine2005
May 12, 2015
5,318
Difficult to say. That’s why temperature controlled solder stations are ideal but can be expensive.
I have a 100W iron for large surfaces and sometimes a heat gun too to preheat the surface.
But in your case, you’d need to remove the solder or file it down in order to use crimps. Look on eBay for a cheap 60W or 100W iron. It’s certainly a good idea to have one if you tinker enough.
juntjoo
Jun 8, 2015
142
@Martaine2005 thanks. I may do that. I don't not tinker enough but just when I don't think I will so I'll see... Why must I clean off solder before crimping? And how would you crimp this? Are these little connectors standard. If I were to destroy one could I easily replace it? I was about to bend the tabs to bridge them together but didn't want to mess them up, but if they're made to be manipulated then maybe I can avoid soldering in this case
Minder
Apr 24, 2015
3,561
I also made some similar copper bar/plate styles of various lengths with the edge filed down to a Vee along its length in order to de-solder IC's one side at a time in just two applications for each side/row.
Martaine2005
May 12, 2015
5,318
No, the connections are not standard. They are specifically designed for your bike. The battery is a third party device.
You would need to clean the solder away in order to use a crimp.
But a better idea is to solder a bus bar to the bridged connection.
It has to be a good solid connection as the batteries can supply lots of Amps and cause a fire.
juntjoo
Jun 8, 2015
142
Well done, it’s soldered.
So how do you disconnect it?
D/C it? It's now how I want it so it will work with my bike. Just rode a few miles. Works like my other stock batteries. This was a better deal on the same battery, just wired a lil different
Delta Prime
Jul 29, 2020
2,996
Sorry buddy your connection looks like garbage.
It is why you do not solder on 48 Volt systems that can and will take more than the 20 Amps,soldered connections will melt . it is why they are welded or crimp connected..
you only respond to those who think as you do, but that is bad engineering practice you are performing and you will soon find out why when you’re on the road and you, peg the throttle…your connection will melt away.
juntjoo
Jun 8, 2015
142
Well it was originally soldered. I just re-did it to make work with my bike
Martaine2005
May 12, 2015
5,318
Soldered connections (if done correctly) are very low resistance so won’t/shouldn’t heat up.
Now, if inferior wire or wrong gauge is used, the wire can heat up and melt the solder. That’s not the solders fault, it’s bad engineering!.
My battery packs include a 72V. The cells are spot welded and the battery terminals are soldered.
Granted, others are spot welded but not all.
In the OPs case, the terminals were originally soldered too.
Just my 2 cents.
Minder
Apr 24, 2015
3,561
I agree, I prefer to clean a connection up by removing all the evident oxidization first!
Martaine2005
May 12, 2015
5,318
Blimey guys, give a little credit where it’s due.
The OP can’t solder but got it done somehow.
Even admitted that it’s not the prettiest!.
Remember, we all started at the beginning.
