H
Harry Dellamano
- Jan 1, 1970
- 0
Winfield Hill said:Actually, my circuit above is a short-changing cheat!
It has no standing bias for the critical transistor,
Q1, and hence cannot perform to the desired bandwidth
when Iout is near 0mA. Adding a bias like the original
non-opamp BJT current-mirror circuit, boosts the parts
count to 15, exactly the same as the all-BJT circuit.
So it's a tie. Go to the trouble of finding a suitable
low-current high-side opamp and get better zero-current
accuracy without trimming. Or something like that.
high-voltage fast high-side current monitor
10.0 +250V Iout
------+------+---/\/\----+----o ---> 0 to 10mA load
\ 200 | | |
/ 1% | 200 / |
| | 1% \ |
| _|_ | | | | 7.5V zener
Q1 e / -|--' | _|_/ |
mpsa92 b ---< | | /_\ _|_
PNP c \__+|------+ | --- 0.1uF
| LT1783 | | | |
\ 1k 1.0M | / 330k
/ / \ 0.5W
| Ib = 0.25 \ Ia /
| to 0.75mA / |
| | gnd
| 10.0k |
+--/\/\---, | 10.0k
| __ | +--/\/\---, 0 to +5V
'--|- \ | 10.0k | __ | out, for
| >--+--/\/\--+--|- \ | 0 to 10mA
gnd ---|+_/ | >--+------
gnd ---|+_/
Going from left to right on the bottom, call the three 10K resistors, R1,
R2, R3 and op amps U1 and U2. Remove U1and R2. Tie the open side of R1 to
ground. Remove the ground on U2 pos input and tie to the junction of R1 and
the 1k. Two less parts and a single supply op amps. Now someone will
complain of the reduced CMR of U2 with it's inputs flopping around at 1.5MHz
but only maybe 50dB is needed..
Not sure of 1.5MHz BW, Q1 has a big pole C to B.
Cheers,
Harry
