Hey, I am trying to make a variable power supply and found that transformers are hard to find in working order when salvaging them. I finally found one that I think will work but the circuit that it was in was complex and even seemed to rectify the signal before sending it through the primary winding which I thought was weird. The transformer seems to be purely the windings and I don't want to blow it up when I plug it into the wall. The battery charger it came from stepped the voltage down to about 5V and I think it might have been regulated but I need to check the parts to confirm this. If I could get a higher output that would be great and I don't need it to be regulated for the purposes I am going to use the power supply for. Is there a circuit I can use to get the transformer to work properly?
