looking for schematic and hook up data for Ultra ult-vx700 ATX ps
jon5500
Oct 31, 2020
74
I have a Ultra ult-vx700 power supply that I want to use in another application besides PC's. Problem is that there are not color coded wires, everything is black wiring or just plugs. I need to know the designations of the 12, 5, 3 V lines. Also, whether or not it can operate without being hooked up to a load and, if not, I will place a resistor across the 5V line and ground. Finally, as in a normal PC supply with green color to ground turning it on, how about with this one? I've googled all this and don't come up with anything so far. Thanks in advance!
ramussons
Jun 10, 2014
475
You have an option of going by the pin numbers on the 20 (or 24 ) pin Molex connectors.
Google for "ATX PSU Connectors"
Better to have a minimum load of an Amp or 2 on the 5 Volts line.
jon5500
Oct 31, 2020
74
Thank you both, just what was needed. I definitely can proceed from there!
Martaine2005
May 12, 2015
5,318
As a side note, you can buy ( lazily) ATX 20 and 24 pin break out boards. Between £3 and £15.
Martin
