How to limit solar charger current
shreya shah
May 3, 2021
6
I have 6 amp solar charger. I want to limit its current to 2 amp is it possible? If yes what is its circuit?
Audioguru
Sep 24, 2016
3,656
Parts that limit the current are shown on the charger schematic that you did not post.
shreya shah
May 3, 2021
6
I have 12V/6A readymade charger its schematic is not available with me.
I have 12V/40watt solar panel its short circuit current is 2.64 Amp and i have 26AH sealed Lead -Acid battery.
I am worried that due to charger current capacity it can damaged my solar panel in future or not.
and for that i required some external precaution to limit my current to 2Amp or 3 Amp.
Panel can only supply it's maximum output........battery can handle near 8A charge.
Don't see the problem.
shreya shah
May 3, 2021
6
Let me reframe the query.
At any instance lead acid SMF Battery can accept up to maximum 20% of current capacity. For 12V/26AH battery, it will be 5.2AH.Solar battery charger can pass upto 6A current as per its specification. Take a case where we connected 12V/40Watt solar panel (which can give Max. 2.66A current) and 12V/26AH Lead Acid SMF Battery to solar battery charger. Do you think that any time solar panel may get damage due to excess current (>2.66A) requirement by battery? If yes, what we need to protect solar panel in such condition?
14,312
The solar panel cannot deliver more than the rated current. Is more current is drawn, the output voltage will fall and thus current.
Of course, the best method is to limit the current within the charger. If you try to limit the current externally that will interfere with the operation of the charge.
