How to make a circuit to test ringers in rotary telephones ?
Electric Al
Jan 16, 2014
85
From 120 volt a/c or from a battery source .... how to make a ringer tester for rotary telephones , without a connection to a telephone line ?
I have a ringer which requires 12 volt d/c primary and the secondary Vout is supposed to be 70 v r m s .
I can not get any secondary output voltage at all , and I assume the circuit is open !
It is intended to produce 70 V r m s (V out) and 3 W r m s (P out) at 20 Hz.
Is there any other way to achieve the correct voltage I need to temporarily ring a rotary telephone ?
Any help will be appreciated !
Martaine2005
May 12, 2015
5,315
Is this the OLD rotary phone with the two large caps and relay/solenoid?
Electric Al
Jan 16, 2014
85
Standard rotary Telephone eg: Northern Electric or Western Electric 500 series .
Externet
Aug 24, 2009
944
I have done it maaany times, by connecting the telephone to 110VAC 60Hz with a 10K resistor in series to test ringers.. The telephone must be on hook or you will fry it.
14,484
you need to clarify that ... you cannot put DC into a transformer and expect an output voltage
transformers require AC
I'm referring to transformers because you specifically refer to primary and secondary
Electric Al
Jan 16, 2014
85
I did not say that it is a transformer !
It is a manufactured printed circuit device .
I will locate it and post a picture !
PowerDsine
Ringer.
P/N:pCR-SINO3V12F20-C
Vin:12VDC
Vout:70V rms
Pout:3W rms
Frequency:20 HZ
MADE IN ISRAEL.
Unit is 2" by 2" and 1/2 " deep .
14,484
as I said ..... I only suggested that because you used the words primary and secondary ....
these are used to describe a transformer
this is why its important to be very clear describing something
so that you don't make it even more confusing for those trying to help you :)
and speaking of being clear ... did you not look at that pic before posting it ???
its totally blurry and unreadable ... I have deleted it
there's no point posting something that isn't readable ;)
try again
Electric Al
Jan 16, 2014
85
I realized the picture was blurry , and that is why I wrote all the info on the device .
I probably should not have submitted the image , but that was the best I could do !
14,484
OK
Im not wanting to be or sound harsh, just trying to help you OK :)
