Simple Circuit to test TT Slotted optical switches
Minder
Apr 24, 2015
3,561
Simply supply a resistor in series with the input diode rated under the spec sheet maximum. and dependant on the test voltage used.
On the output, use a 5k to 10k resistor to common (GND) from the output emitter, connect collector to a +ve
From the emitter connect to the gate of a 2N7000 , 2N700 source to common, 2N700 drain to a suitable indicator LED with series resistor etc.
