How to make a ferrite bead equivalent circuit?
Mr.Blank
Nov 21, 2017
12
Someone willing to help me on how to select components and its value for making a ferrite bead equivalent circuit?
14,487
ferrite bead equivalent ?
a ferrite bead has a hole and a wire passing through it one or more times
there are small ferrite bead type inductors in SMD format
What are you trying to achieve ?
Mr.Blank
Nov 21, 2017
12
..Sir im trying to make an RLC circuit which has a functionality as a ferrite bead
14,317
Doesn't make a lot of sense to me.
Anyway: Look at the datasheet of the ferrite bead you want to model. Follow these instructions to create a model using RLC components. Build the model from real components.
Note that the resulting circuit will be rather complex if you want to fit the characteristic of the ferrite bead with reasonable accuracy.
Similar threads
Replies
9
2K
Fred Bartoli
F
Replies
35
11K
John Popelish
