How to select Vref?
sid2286
Aug 24, 2011
102
I'm using PIC18F4520 for my project. my input for ADC is 200mV to 1.2V.
now i want to give vref to my microcontroller. It has to pin RA3/AN3/
VREF+ and RA2/AN2/VREF-/CVREF pins.
So how do i give Vref? should i apply 1.5v to only VREF+ and keep open VREF- or should i ground the Vref- pin??
Please help.
Rgds,
Sid
GreenGiant
Feb 9, 2012
842
it should be you only have to connect the 1.5 to the +Vref but connecting ground to the -Vref should not have any negative affects, this is drawing from experience with Arduino's NOT PIC's so I'm not 100% sure if they work the same
In PICs you can separately specify whether Vref+ and Vref- are internal or external. You would leave the Vref- internal, which connects it to ground and frees that pin for other uses. Also check the datasheet for the minimum Vref. I think 1.5V is going to be too low.
