How to test a capacitor
Karthik rajagopal
May 9, 2016
257
Hi all,
While debugging using a normal DMM I am able to measure resistance, continuity etc.. but I am not able to measure a capacitor for me to know whether it is in a good condition and even a voltage regulator. Please help me .
Alec_t
Jul 7, 2015
3,821
What do you mean by 'good condition'?
It is relatively easy to measure capacitance, but not so easy to measure, for example, breakdown voltage of the dielectric or to detect intermittent internal faults.
Herschel Peeler
Feb 21, 2016
401
Hi all,
Is it shorted? If so it's bad.
You could undo one side of larger capacitors and see if they hold a charge. Charge it up on Ohms scale. Switch to voltage and see if it held a voltage.
14,487
that's going to be very unreliable as the cap will discharge through the meter pretty quickly
buy a DMM that has a capacitance test section on it .... they are very common these days
Karthik rajagopal
May 9, 2016
257
Thanks for the suggestions. How to test a voltage regulator without desoldering it from the PCB ?
Karthik rajagopal
May 9, 2016
257
Will it work? Will the charge in the ohms scale be enough for the capacitor to get charged?
Herschel Peeler
Feb 21, 2016
401
depending on the size of the capacitor, that is true. Yes, ,buying a capacitor tester is a better idea.
I just put "capacitor tester" in an Ebay search and came up with hundreds BUT you may want to go for a multimeter with a capacitor test range included. Might be more handy for other things as well at around the same cost.
Depends what range you need to test capacitors at. The specific tester may well cover a broader range.
14,487
with the multimeter in the appropriate voltage range
black lead probe to the 0V (negative) and the positive probe first onto the regulator input pin, note the voltage
then move to the output pin and note the voltage ( should be whatever the regulator is spec'ed for)
There are many inexpensive component testers now available on Ebay. These will test resistors, capacitors, diodes, inductors and transistors. For capacitors they will give you the capacitance as well as ESR.
bsco
May 8, 2011
33
get yourself a capacitor tester and an ESR tester.....the cap tester will test for rated capacitance while the ESR tester will test for Effective Series Resistance...A decent cap tester will cost around $75 and an ESR tester will be slightly more depending on where you buy it...ESR testers can also be built and there is lots of info on google and youtube about it.....
SPLatMan
Apr 22, 2013
8
As BobK suggested, there are cheap, effective component testers based on an open source design by a chap in Germany. I got one a couple of weeks ago and it's instantly become my go-to instrument for checking transistors, diodes, caps, resistors. I just took a pic for you with it testing a relay coil. I bought mine from BangGood. http://www.banggood.com/MK-328-Tran...Resistor-Meter-LCR-NPN-PNP-MOS-p-1010347.html but I'm sure you can get them elsewhere.
tilup367
Mar 3, 2014
13
Hi all,
So, capacitor just like resistor have a acceptable tolerance. So let said a 10 uF capacitor with +-10% mean the capacitor is good if his capacitance is between 9 and 11 uF. Then, if your capacitors are "in-circuit" you MUST unsoldered them because other capacitor or inductor or even resitance may false your reading.
Kaj Lonnqvist
Sep 3, 2014
5
Hi all,
Guess the best is to buy a cheap DVM with capacitor testing included. Otherwise you must use an AC source (e.g. a tone generator) and connect the capacitor to test i neries with a known good capacitor, maybe in a Wheatstone bridge configuration.
poor mystic
Apr 8, 2011
1,106
Hi :)
Internal leakage in electrolytics, at rated voltage or below, can cause problems. These problems often appear in the circuit as noise.
