How to test a capacitor
poor mystic
Apr 8, 2011
1,106
Thanks for the suggestions. How to test a voltage regulator without desoldering it from the PCB ?
Hi :)
See if there's current going in, see if the right voltage is coming out, try and burn your finger or otherwise see if the chip is hot.
PS the chip ought be hot
FuZZ1L0G1C
Mar 25, 2014
366
Colloquially, the Volts/Ohms/Amps DMM's are known as "Electrician's or Electrical test-meters", whereas the ones that do Capacitance, Frequency, Diode test and Inductance are often advertised as "Electronic test-meters".
You can also browse the web for multiple "Capacitance meter" project circuits, to construct your own.
