How to test buzzer
ratstar
Aug 20, 2018
485
Yeh id say its not a normal buzzer looking at that code, it would be a milliseconds I think if its the same as timeGetTime() in c++ windows code.
Djsarkar
Jul 27, 2020
46
An alternating sequence of high and low (1 and 0) generates a square wave at the output to drive the buzzer.
delay() is in ms.
Thanks to all now buzzer/speakar is working
Code:
#define _XTAL_FREQ 8000000
#include <xc.h>
// PIC18F45K80 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config RETEN = OFF      // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH   // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF       // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2    // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF     // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF       // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF     // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS  // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3         // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576  // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB    // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7   // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON       // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K     // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF        // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF        // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF        // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF        // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF        // Code Protect Boot (Disabled)
#pragma config CPD = OFF        // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF       // Table Write Protect 00800-01FFF (Disabled)
#pragma config WRT1 = OFF       // Table Write Protect 02000-03FFF (Disabled)
#pragma config WRT2 = OFF       // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF       // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF       // Config. Write Protect (Disabled)
#pragma config WRTB = OFF       // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF       // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF      // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF      // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF      // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF      // Table Read Protect Boot (Disabled)
void Port_pins_Initialized (void)
    LATA = LATB = LATC = LATD = LATE =  0;
    TRISA = 0b0000000;// all are output, Unused
    TRISB = 0b0000000;// Buzzer connected to B0
    TRISC = 0b0000000;// all are output, Unused
    TRISD = 0b0000000;//
    TRISE = 0b0000000;// All are output, Unused
    ANCON0 = 0; // digital port
    ANCON1 = 0; // digital port
    CM1CON = 0; // Comparator off
    CM2CON = 0; // Comparator off
    ADCON0 = 0; // A/D conversion Disabled
void main(void)
     int i = 0;
    Port_pins_Initialized ();
    while (1)
          //Frequency 1
    for (i = 0; i <80; i++)
      LATBbits.LATB0 = 0;//Buzzer high ;
      __delay_ms (1) ;
       LATBbits.LATB0 = 1; //Buzzer Low ;
      __delay_ms (1) ;
    //Frequency 2
    for (i = 0; i <100; i++)
     LATBbits.LATB0 = 0;//Buzzer High ;
      __delay_ms (2) ;
      LATBbits.LATB0 = 1;//Buzzer high ; ;
      __delay_ms (2) ;
Djsarkar
Jul 27, 2020
46
buzzer is sounding continuously and I want to sound the buzzer for 3 seconds and two seconds of silence when push button pressed
Code:
#include <xc.h>
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#define TRUE 1
#define FALSE 0
    TRISB = 0b0000001;// Buzzer connected to B0
__bit Button(void)
    if (PORTBbits.RB0 == 1) // if button not pressed, return FALSE
            return FALSE;
    else{
        __delay_ms(5);      //  button pressed, debounce delay
        if(PORTBbits.RB0 == 0) // if button is still pressed..
            return TRUE;
        else
            return FALSE;
void main(void)
     int i = 0;
    while (1)
           if(Button())
           { // if button is pressed and debounced
ratstar
Aug 20, 2018
485
if button then buzzer=off and start a timer that counts so long, then if timer=2seconds then buzzer=back on
but ull have to get the button request to break out of that for loop that is running through the two frequencies. youll get it! welcome to hardware code. =)
Djsarkar
Jul 27, 2020
46
I have button routine that check the status of button. When the button pressed buzzer should be give sound for 3 seconds. Then it should be turn off.
As shown in code I am calling button function in main so I only don't understand how to write code for buzzer that would be turn on for 3 seconds and then it would be turn off
hexreader
Apr 21, 2011
139
I now have a PIC18F45K80 and I am not afraid to use it :)
Solution attached - based on OPs own code on AAC forum
Code:
#include <xc.h>
// CONFIG1L
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#define TRUE 1
#define FALSE 0
#define Buzzer             LATDbits.LATD0
#define Buzzer_HIGH           1
#define Buzzer_LOW            0
    TRISA = 0b0000000;                                    // all are output, Unused
    TRISB = 0b0000001;                                    // Buzzer connected to B0
    TRISC = 0b0000000;                                    // all are output, Unused
    TRISD = 0b0000000;                                    //
    TRISE = 0b0000000;                                    // All are output, Unused
__bit Button(void)
            return FALSE;
    else{
            return TRUE;
        else
            return FALSE;
void main(void)
    int i = 0;
    unsigned int count = 0;
    while (1)
        if(Button())
            //Frequency 2
            for ( count = 0; count < 750; count++ )
                Buzzer = Buzzer_HIGH;
                __delay_ms (2);
                Buzzer = Buzzer_LOW;
                __delay_ms (2) ;
hexreader
Apr 21, 2011
139
Just spotted a commenting error:
Code:
Should be:
Code:
    TRISB = 0b0000001;                                    // Button connected to B0
Code work just the same, but the comment is confusing
