How to test if I am grounded properly to work with electronics?
SoulReaver009
Mar 20, 2023
Hello people of "All About of Circuits"!,
I am new to electronics. Been fascinated by it for a while, have studied physics (not Electricity, yet, but its my next unit). I got a multimeter and an Ardist DIY kit for my birthday and I am very excited to start testing, experimenting, and building!
I have been googling and youtubing a little bit, watching some reviews on my multimeter, and reading my manual and such.
For some reason I cannot find a video or webpage to test and confirm if I am properly grounded.
I can only work in my room, and it has carpet, so I am very nervous. I cannot work anywhere else, sadly.
I watched a youtube video that said to plug in a 3-prong laptop charger, and then connect the alligator clip of my ESD anti-static wrist strap to the outside metal part of the charger (the part that goes into the laptop).
Lots of people have commented that it works and i believe them. If you know other ways to ground, I would be interested. Would also be cool to test each method of grounding, and compare results.
Being the experimentalist that I am, I would like to have a procedure to test and confirm (as closely to absolutely, as possible) if I am indeed grounded, or at least within a safe range to "work with electronics". please forgive me if my terms or sayings are inaccurate or wrong. I am new to this!
Can't wait to hear back and get started!!
Delta Prime
Jul 29, 2020
2,996
Okay I'm over it I was just kidding here you go buddy
dragon
Oct 31, 2022
248
Its not that important, If you get a few electric shocks off some in circuit batteries it probably puts extra hairs on your knuckles.
14,317
Grounding as requested by the op is not about getting shocked yourself but about protecting the electronic components from getting destroyed by electrical discharges, cf. post #4.
Of course that's completely irrelevant for your simulations.
kpatz
Feb 24, 2014
334
If you’re experimenting with electronics you’ll probably want to get a bench power supply with a 3 prong plug. Many of these have a ground terminal on them, so you could ground yourself to that. That would be the easiest way. Laptop power supplies are often ungrounded or have plastic cases.
You could wear a grounding strap, but if you just touch something grounded before handing sensitive components/boards you should be ok. As a kid living in a cold climate I used to get shocked walking across carpets and touching doorknobs etc. so I have a nervous habit of touching anything and everything metal as I walk… so I have a habit of grounding myself. Lol.
dragon
Oct 31, 2022
248
I dont understand the ground, batteries dont seem to conduct to my kitchen sink, I tried.
Martaine2005
May 12, 2015
5,318
Is your sink metal?.
Anyway, a metal sink and copper pipes are grounded (earth ground) called ‘bonded’. not battery negative.
Do yourself a favour and us, read about earth ground, chassis ground and neutral.
