how to test optocoupler using multimeter?
Minder
Apr 24, 2015
3,561
If it is the style where the base has a pin, check with the method usually used on the meter diode range.
From base to C & E with reversing polarity of the meter.
M.
Zippora
Aug 26, 2016
13
Thank you for the reply.
It is 4 pin optocoupler. So only emitter and collector pin is out on transistor side.
HellasTechn
Apr 14, 2013
1,579
if it uses a led then you can use the diode setting. again I don't know how to measure the transistor. if it uses a laser then I am not sure how either.
14,317
Use a battery and a series resistor to control the LED side (turn it on/off).
Use a multimeter in Ω-range to check conduction of the transistor when LED is on, non-conduction when LED is off. That way you check the full photocoupler, not only one part of it.
If you want/need to qualify the photocoupler in more detail, make the LED curent controllable (controlled current source) and wire the transistor side with load resistor and voltage source. Measure collector current as a function of LED current and compute the current transfer ration Ic/Iled.
Get a datasheet for the photocoupler, these typically show recommended test setups for the component.
Zippora
Aug 26, 2016
13
Thank you.
