how to turn on Mentor Calibre extraction of mos AD, AS, PD, PS... in command file?
Boki
Dear All,
Could you please tell me how to turn on Mentor Calibre extraction of mos AD,
AS, PD, PS...
there are only parastic capacitors after I used new version of command
file...
where should I go to modify?
Thank you very much!
Best regards,
Boki.
K
Kevin Aylward
Boki said:
Dear All,
file...
You'll need to explain things a bit better. If mentor follows the same
syntax as HSpice, AD, AS, PD, PS might not be present on the mosfet
spice line itself. These parameters are automatically calculated from
the "hdif" parameter in the .model.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
boki
Kevin Aylward
[email protected]
I am very sorry, I mean the LPE in Cadence + Mentor Calibre...
Sorry.
Boki.
