Need help to wind wire on yellow/white khz toroid core to match power inverter output to ISOLATION TRANSFORMER to 4 ohm load and higher 32 volts AC output. Inverter is 20,000 cycles, 16v AC, about 200 watts, about .063ohm resistance impedence on contacts with below 1 microhenry inductance secondary side. (Several attempts not going over 15 volts out on high frequency analog multimeter)
