How to wind toroid for audio frequency matching to ouput ?
russwr
Dec 20, 2019
39
I need to wind Impedance matching transformer of 20khz inverter power output to 4 ohms load? Source is 16volts AC, 20,000 cycles , about .06ohm contacts ohms impedence, and less than 1 microhenry inductance. I have matching khz yellow/white toroid core which will be used also same time as isolation transformer for final output step up 32 volts AC/? Voltage will be read on analog high frequency multimeter.
