How two use this transformer for PSU.
Dazza
Jun 21, 2004
591
I'm not sure how I can use this transformer it has, 10.5V(9.5A) 0V 10.5V(9.5A), what output V and A can I get?. 12VDC would be ideal, with 9.5A or more would be good, I have made some sparks trying to work it out, so I thought I'd better ask the experts before I do some damage.
I want to use it to power my cordless drill and screwdriver, it would also be very handy for my hydrogen experiments.
I made this power supply from Electronic Lab, 3-30 V/2.5 A Stabilized power supply.
Would I be able to modify it to use for this purpose, I only need to control the voltage
Thanks in advance.
steven2
Jan 19, 2004
1,698
:)dazza that looks a bit similiar to one ive seen in a high voltage bug zapper , i looked at years ago, it had a high voltage multiplier and this wierd transformer like the one you posted , i geuss you could try finding the primary of it by setting your multimeter to low ohms and use that to find it if you do, the other wires may be the outputs, if ive got it right , i used that to find the primary for a toriodal transformer as exsplained to my by an electronics tech over the phone, long time ago i hope i remember it corectly
Dazza
Jun 21, 2004
591
Hi steven, I have no worries working out the primary and secondaries its written on it ;D. What I'm not sure about is the secondaries, there is 2 x 10.5V 9.5A what voltage and ampere output can I achieve and how?
The transformer was used for electrolysis ;), for producing chlorine for a saltwater swimming pool. My neighbour gave me the device, and he said that the transformer had failed but it was one of the power transistors, I offered to fix it for him but he wanted to buy a new chlorine maker, I'll call it that because I don't know the proper name of the device.
steven2
Jan 19, 2004
1,698
:)dazza measure the ac output with your multimeter in the ac range , as for measureing dc amps i do it through a 0.1ohms resister . but im not sure if you can do it the same way for ac useing a 0.1ohms resister but if you could do it id use a 0.1ohms 5 watts
Dazza
Jun 21, 2004
591
steven, everything is written on the transformer 8);D. what I am unsure of is, how to configure the four wires on the secondaries, what V and A can I achieve 10.5V and 19A?? or 21V and 9.5A or 19A??.
[move] ;D ;D ;D ;D ;D[/move]
Dazza
Jun 21, 2004
591
Hi ante, ok great extremely useful, what I would like to try to do, is be able to switch between 10.5V @ 19A and 21V @ 9.5A, it's fairly straightforward to achieve this, I just have to make sure that whatever I use for the switching can handle the high current.
I just need some help to modify the circuit to be able to very the voltage and handle the high current. For starters D1 will have to be upgraded that one is easy. I don't know how many power transistors I'll need?? and can I simply parallel them. R5 will have to be fairly hefty what should I use here?. Also I'll have to beef up the PCB tracks.
This project will be a real asset for my hydrogen experiments :D,
Thank you for your help,Steven,Ante :).
Kevin Weddle
Feb 23, 2004
1,620
All you need to do is figure out the circuit for it. You can figure the 0 is a center tap and you can check it by using your ohmeter. You can probably assume the voltage is rms. This means you have a 20vrms output with a center tap.
ante1
Jan 24, 2004
4,138
Hi Dazza,
The bridge rectifier (D1) should be a 35A type. The power transistors, if you want 3Volts output at 9.5A at the
Dazza
Jun 21, 2004
591
I discovered why I ran into problems trying to work out what A and V I could achieve, there was a short between the two wires that were insulated together. Once I separated them no sparks, when trying to configure them ;D. Pretty thick of me, I should have realised ::).
Thank you everyone for your help :),
