Constant Voltage Transformer for PSU
Richard
I have a constant current transformer - along with capacitors and chokes
and a PCB with electronics, from a Motorola or Schumacher battery
charger (Motorala Type: 25E83071P03 or Schumacher 93-013-419). I think
made in 1990. Outputted 14.25V or 13.8V depending on which outer taps on
secondary was chosen.
I've no idea what the electronics did on the PCB, but centre-tap (CT) of
secondary is positive and the outer taps go to chassis via rectifiers.
CT goes to a capacitor of 97,000 uF, and then a choke, then another
capacitor of 73,000 uF.
Wires (probably "signal" voltages) from both of the outer taps of
secondary goes to the PCB.
The tank circuit has the capacitor. But both ends of the capacitor go to
the PCB - one of the wires via an iron-cored choke (not some small RF
choke).
Okay, the question is, can a basic PSU be made with the following items
only?:
* CVT
* both rectifiers
* both "smoothing" capacitors
* smoothing choke
* capacitor for tank winding
All the rest not used.
Thanks.
Rich Grise
and a PCB with electronics, from a Motorola or Schumacher battery charger
(Motorala Type: 25E83071P03 or Schumacher 93-013-419). I think made in
1990. Outputted 14.25V or 13.8V depending on which outer taps on secondary
was chosen.
secondary is positive and the outer taps go to chassis via rectifiers. CT
goes to a capacitor of 97,000 uF, and then a choke, then another capacitor
of 73,000 uF.
choke).
only?:
* CVT
* both rectifiers
* smoothing choke
Yeah, but the only regulation you'll get is what the CVT regulates
to. (or whatever you slap onto the output) What you've just described
is the bog-standard introductory basic DC power supply. :)
Now, if this CVT is actually something like a mag amp, then, of course,
all bets are off. ;-)
Have Fun!
Rich
Richard
Have Fun!
Rich
Basically I would have ended up with something similar to:
http://www.circuitstoday.com/wp-content/uploads/2009/10/CVT-Power-Supply.jpg
I had parts for a more sophisticated circuit arrangement where the
voltage across the AC capacitor was fed to a PCB, via a (rather large)choke.
Anyway, on leaving out the connections to the PCB, I'm sure I would have
got a working PSU similar to the circuit in the link.
But, I've decided to take all the windings off the core, I've removed
the magnetic breaks, and I'll rewind for a conventional transformer.
So, my project has completely changed! It's now about winding a
transformer.:c)
GregS
Constant-voltage transformers are NOT TRANSFORMERS. They do
not have a single magnetic circuit with primary and secondary
windings,
Leave it in its original configuration, it's not nearly as useful in
any other
circuit.
I remember the supplies they used to use on the early DEC computer
systems. Just a CVT, rectifier, and "computer grade caps".
greg
Rich Grise
By 'remove the magnetic breaks' you mean you are changing the magnetic
core configuration? This chunk of iron was NEVER intended to make a
simple transformer, it was an integrated magnetic component of a
transformers/saturating link/resonant assembly, and was well designed for
that purpose. That purpose only.
It also delivered regulated AC output. It's PERFECT for driving, for
instance, 12V halogen lamps (they last longer on AC).
Not to worry too much; it will work as a conventional transformer, the
iron is the same, it's just terribly stupid and wasteful to tear apart
an already working ferro-resonant transformer. The guy probably won't
burn the house down, but he's shot himself in the foot by degrading
a working ferro CVT to a linear.
I used to work for a guy who designed ferroresonant transformers. The
"official" name for those "magnetic breaks" is "shunt(s)"
Take them, and the resonant winding away, and it's no different from any
other silicon steel transformer core, except for the HUGE winding windows.
One time, he designed a new ferro xfmr, and I was at the bench testing
it - there was a mongo variac with a knob about the size of a steering
wheel, and big AC voltmeters and ammeters.
So, I plopped this brand new ferro transformer on the bench, start
cranking up the variac, and at about 3 VAC on the primary, it was drawing
about seven amps! I freaked, looked at the boss (the guy with the black
magick knowledge of how to design one of those beasts), and he was
beaming: "It's regulating!"
The primary makes more flux than is needed; the shunts let that flux
slosh around the core, which might or might not saturate on the peaks -
the resonant winding makes saturation pretty much irrelevant, because
the magickal confabulation of the magnetic shunts and the resonant circuit
(they use big can capacitors for what he called "the ferro winding")
result in a pretty much constant-voltage output.
I agree, it's kind of stupid to dismantle a working ferroresonant
constant-voltage transformer; but the worst that will happen is:
1. If you don't use enough turns in the primary, it will burn out,
same as any other iron core coil across the mains;
2. All you'll have is a plain ol' ordinary linear transformer, with
all their attributes, so to speak.
The reason not to tear it apart isn't danger, it's why screw up something
that's already working as advertised? And he could very easily have
changed the number of turns on the secondary to get any output he wanted.
Cheers!
Rich
Richard
Cheers!
I thought if it was not drawing it's load current, it was going to be
wasting power. I know they run hot. So, I thought, make it a regular
liner transformer.
It could be put back again, in theory, but I'll just dabble and
hopefully make a nice regular linear transformer. Rich
Similar threads
