I am looking for an SF152E thermal fuse
Thor
I am looking for an SF152E thermal fuse. This is used in a tabletop distiller.
The distiller plugs into an standard 115volt 15 amp outlet(USA). This is a 152
degree C fuse rated at 10 amps.
Here is a link to a pdf,
http://www.digchip.com/datasheets/download_datasheet.php?id=864056&part-number=SF152E
I am able to find the fuse on ebay but the guy is asking $8.95 plus $2.00
shipping, yeesh! I can get them from Chatham Components for $2.00 a piece but
they have a 10 piece minimum policy, plus what ever shipping. It is a toss up of
$10.95 for one or $20.00 plus for ten. I checked Mouser, Digikey and Jameco with
no luck.
Hmm, Hosfelt has 15 amp thermal fuses but that may be too high an amperage.
This morning I replaced the dead fuse with another , I wish I wrote down the
specs, but it was a 139 degree C. So far it is working ok but I would rather be
prepared for when it goes again. I believe the fuse failed initially because the
distiller gets plugged and unplugged, a spike drooping the fuse until failure or
just plain old age got it.
Thanks for any help,
Thor
N
N_Cook
er=SF152E
no luck.
Thor
Could you just remotely monitor the fuse temperature with a calibrated diode
, fixed to it, and DVM on diode test. Then move the present fuse further
away , until it is about 10 degrees less in temperature, in operation ?
Assuming a 1N4001 can go to 130 degrees or so , untroubled
Thor
Not readily. The heating element is on the bottom of the distiller and so is the
thermal fuse. You put a gallon of water in the tank and then it boils it all
out, until the thermostat(preset) clicks the distiller off.
Here is what it looks like,
http://www.nutriteam.com/servlet/the-3/distiller-water-distillers-water/Detail
The stainless steel basin is inside and bolts down through the bottom plate,
which fits VERY snuggly. I couldn't leave everything unbolted so I could get a
probe up in there.
I am almost positive that the fuse went out not because of over temp or amperage
but because of fatigue. I think these things are supposed to be throw away items
lasting only about a year and I have had this around 6 years. I got the
replacement fuse from my older distiller, it was about 6 years old too and rust
got the better of it.
I forgot about BG Micro,
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=12325
Much better than $ebay$. I just wish that BG Micro had .187(3/16") female quick
disconects too, my older distiller is all 1/4".
Thanks for the reply, I may end up using it if push comes to shove later on.
Thor
PeterD
Buy 10 from Chatham. Keep two. Sell remaining 8 on eBay for $5.95 plus
shipping.
Baron
distiller. The distiller plugs into an standard 115volt 15 amp
outlet(USA). This is a 152 degree C fuse rated at 10 amps.
$2.00 shipping, yeesh! I can get them from Chatham Components for
$2.00 a piece but they have a 10 piece minimum policy, plus what ever
shipping. It is a toss up of $10.95 for one or $20.00 plus for ten. I
checked Mouser, Digikey and Jameco with no luck.
amperage.
If its the right temperature and physically fits then use it ! The 15
amp is the max current carrying capacity without it failing.
down the specs, but it was a 139 degree C. So far it is working ok but
I would rather be prepared for when it goes again. I believe the fuse
failed initially because the distiller gets plugged and unplugged, a
spike drooping the fuse until failure or just plain old age got it.
All that will happen is the fuse will fail at a lower temperature.
F
Franc Zabkar
Sjouke Burry
Franc said:
Add a 10A regular fuse in series ?
- Franc Zabkar
Thermal fuses are not supposed to act as a normal fuse.
The current spec is not a fuse current, but it tells what
the thermal fuse can stand without failure.
So just use the 15A part, the temperature spec is the important one.
