devilman96
- Apr 5, 2012
- 2
- Joined
- Apr 5, 2012
- Messages
- 2
I have a project that I am working on which requires a reversing timer board that I can not buy. Where as Im pretty self sufficient in doing these things I currently have about a billion and one hobbies to keep up with and really don't need to add another pile of chemicals and parts or pieces to the mix... nor learn another type of cad to have it produced by a manufacturer...
Attached is the basic layout... I need a board produced that has 5mm screw type connections for wiring power, motor, timer and limit switches... the board needs to be rated for 5 amps for the motor, I would like to add a fuse holder to the + and add a momentary push button for testing between + and the timer. A weather resistant coating would be nice as these are housed in outdoor enclosures. (Solar chicken coop door opener) Robust is a must... I.E. use 15 amp relays, etc...
Added wish list... If your capable of adding in a simple voltage control circuit for a 5 to 15 watt charging panel (12.5v cut off) that would be another nice feature to consider... A lighting control circuit that is capable of turning on after close for adjustable time period 1 to30 mins? (10-20 watt led light source) would be another nice feature. As would a 12v warning circuit for fail to open fail to close for an external piezo... (just thinking out loud)
I would like to have 3 to 4 prototypes made and would like the cad file and parts list used.
If you are interested in doing this have questions or ideas please POST them... the more people thinking out loud the better off we all are.
Regards
Mike
Regards
Mike
