I just do a design of lm386-based audio amplifier circuit
erinxie
Oct 27, 2022
4
Hi everyone, I just did a design of lm386 audio amplifier circuit and get a problem,
Design steps:
  • First, think about the chip based on its function, thus designing the circuit
  • Second, to understand the nature of the chip, characteristics.
  • Third, use DXP software to draw the circuit schematic.
I could not use DXP software, how to fix?
HarryA1
Mar 4, 2009
481
You need to supply a link/url to the DXP software you are using. There are numerous software packages called DXP.
bidrohini1
Feb 1, 2023
102
I think it's not possible to give a good answer without knowing which specific DXP softaware you're using and what error you're facing.
bidrohini1
Feb 1, 2023
102
loribennms said:
I used Lm386 as an audio amplifier, 9V , and when I check the output waveform it amplifies but it was clipped. I just copied the circuit diagram on its datasheet. How to fix this? Any advice there in making an audio amplifier with good sound quality ?
You can add a decoupling capacitor. Sometimes, the output waveform can be clipped due to noise in the power supply. Adding a decoupling capacitor between the power supply and the ground can help reduce the noise and improve the output waveform.
erinxie
Oct 27, 2022
4
