I need help (KVA)
george
I would like to know the Kva for the following appliances.
4 freezers at 5 amps each
3 chiller units at 3 amps each
2 chillers at 35 amps each.
I do not know if they are resistive or conductive(if that is necessary
for the answer)
Would the answer be 79 * 240 /1000 = 18.96??
Hope you can help.
Confused
GotCoffee
If all you appliances are running off of 240 you're almost correct...
you for got to add in the 4 freezers so add 20 more amps and you should
come up with 23.76kVA
Don Kelly
That is an upper limit - assuming all are running at the currents given and
all are at the same power factor.[/QUOTE]
